Speaker upgrade
Old May 5, 2003 | 12:19 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Speaker upgrade
Hey all,
I'm looking to upgrade my speakers to some rockford fossgates. What is the size for the front door speakers, rear and rear deck? Also, i took out the speaker cover and saw that it (factory speakers) are on mounting brackets of some sort? Do I take those speakers off the brackets and put the new one in or what? Anyone have experience with this from b4? btw, it's a 94 C220. Thanks!
-Greg
Old May 5, 2003 | 02:04 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
u can use crutchfield as a quick guide
Old May 5, 2003 | 10:18 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
I've tried looking on there, but for the 94's, they dont have the speaker sizes or even the speakers available for 94's. All they have when I look up my car are the kickpanels and CD changers...
Old May 5, 2003 | 12:27 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
If you've got Bose in it you're going to have to rip everything out and replace the whole system, head unit and all. I believe it's two tweets (1-2") in the dash, 4" in the doors, and 6" in the rear. This is my best guess. Overall you're probably looking at around $400-$500 dollars if you replace the whole thing yourself. Installed professionally you're probably looking at a grand or more. Again, this is if you have Bose, which I do believe '94 C 280's came with.
Old May 5, 2003 | 12:43 PM
davinci's Avatar
c220
If you do have a bose setup you can get away with only replacing the speakers but you will have to get a by-pass box. Bose speakers are pre-amped, the aftermarket speakers won't be. The box is like $40.
Old May 5, 2003 | 02:35 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
No bose system. Just regular. I've already changed the deck to a Pioneer DEH-6400. Just sounds crappy with the stock paper speakers....anyone know the size of the speakers and if I can them off the OEM mount/brackets and put the aftermarket ones on?
Old May 5, 2003 | 11:03 PM
steve s's Avatar
u may wanna ask jirwan....he's changed his whole system (recently posted on the c36/c43 board, gear shifter post)
Old May 6, 2003 | 12:09 AM
Winhard's Avatar
2002 CLK430
Just Curious. Do you need to add an amp to drive those door speakers in order to hear the difference??
Old May 6, 2003 | 09:26 AM
95c220's Avatar
C220
This is a pretty good writeup.
Speaker Replacement
Old May 11, 2003 | 04:37 PM
davinci's Avatar
c220
front door 6", rear door 4"
Old May 16, 2003 | 07:59 AM
juk79's Avatar
c230 kompressor'98 "sport"
fron door 165 mm
rear door 100 mm
rear deck 165 mm
fron tweeter from x till y (all)
