Windows & Mirrors, elec fail, '99 C280
Old Feb 2, 2011 | 06:13 PM
oregon's Avatar
C280 1999
I bent the driver's outside mirror toward the front of the car while backing up (it is spring loaded for that). Neither the outside mirror controls nor the side windows work now.
I removed and replaced the fuses for those circuits (mirrors & side windows). No removed fuses had failed, however. I used compressed air to blow out the fuse housing and applied a small amount of electrical contact cleaner. No joy.
I've inspected the drivers outside mirror and I cannot see any out of place, broken or frayed wires.
Aftermarket parts: Radio was replaced about five years ago.
Mileage: 103k
Fuse arrays: large is engine compartment, small is trunk.
Windows & Mirrors, elec fail, '99 C280-02-02-2011c280mercedes1999fuseboxes001.jpg
Windows & Mirrors, elec fail, '99 C280-02-02-2011c280mercedes1999fuseboxes005.jpg
Fuse guides: large is engine compartment, small is trunk.
Windows & Mirrors, elec fail, '99 C280-02-02-2011c280mercedes1999fusediagramslrgengsmtrnk002.jpg
Windows & Mirrors, elec fail, '99 C280-02-02-2011c280mercedes1999fusediagramslrgengsmtrnk004.jpg
The little jewel (mirror looks OK, now if the controls just worked):
Any thoughts? Thank you kindly.
Old Feb 2, 2011 | 09:51 PM
oregon's Avatar
C280 1999
ECU reset
OK, all right. Time is up my friends.
Let me guess my own solution:
1. Hard restart the car's brain: Disconnect the battery, negative lead, for 2 or so minutes.
2. Re-connect the battery.
3. Perform ECU reset procedure (re-windows, key position #2 and actuate window control button to extremes, open and close.
4. Trouble shoot further trouble.
What do you think?
Old Feb 3, 2011 | 12:13 PM
oregon's Avatar
C280 1999
I did the ECU reset: disco the negative battery lead for several minutes (cleaned the terminal and connector while I was at it).
Key in and in ignition position #2: I held all window switches to their extreme position open and closed and recited an old rhyme to mark the time.
Everything works, except the rear passenger side window (this is probably the original offender and not the driver's mirror smack) which I can live with for now.
Thank you kindly forum and forum members.
Road test later this AM.
Old Feb 3, 2011 | 11:38 PM
oregon's Avatar
C280 1999
Results of Road Test:
No issues found. None.
My wife and I took turns driving over 20 miles of mixed road surfaces and speeds on this dry sunny cool day. Nothing seemed wrong with the drivability so I think all is well. Good.
Old Feb 5, 2011 | 01:17 PM
oregon's Avatar
C280 1999
The car did a 40 mile RT commute yesterday over dry and cool roads. When it reached home the electrical problems were back.
Side windows and outside mirror controls didn't work.
I use a different procedure to reset the ECU with mixed results (Working now: top window, passenger front and driver rear side windows work, trunk switch works, passenger outside mirror works and top window works. Not working now: Driver's mirror and side window and passenger's rear window (which hasn't worked throughout this episode).
From another forum (benzworld.org), for your amusement, the simpler and performed from the driver's seat ECU reset procedure courtesy of acousticplayerjb:
1. make sure all the windows are rolled up, doors are closed, lights, radio, fans are all off.
2. turn the key to the second position (on).
3. step on the gas fully until it clicks, which it will because you're hitting the rapid downshift switch.
4. Hold the gas like this for 6 or 7 seconds and then release.
5. Wait in the car for around 3 minutes. Don't touch anything, don't use the radio, don't open the doors, etc.
6. At around 3 minutes, you'll hear the faintest "click" coming from the instrument cluster area. At this point, the process is done and your ecu should be reset.
I tried this twice and did not hear any clicks. Not from the gas pedal nor from the dash board area.
Next move: I am not sure. Dealer service perhaps. I'll see how it behaves when it returns from its commute today and tomorrow.
Old Feb 6, 2011 | 02:17 PM
oregon's Avatar
C280 1999
The next morning: failure summary: both mirror controls and all side windows failed.
I tried the simpler ECU reset x 2, shown above, without any success this time.
I tried the hard re-start: disco negative battery lead for a few minutes (I removed all fuses involved with these circuits and cleaned them again while waiting for the time to pass) and all failed components are working except the usual suspect the passenger rear side window (sigh).
I've hunted and pecked about the internet and have these candidates to point the finger at: ECU malfunction (its memory may be failing), wiring harness failing, key fob programming needs fixing, window controler module inside door & window motor inside door. Did I leave anything out?
Old Jul 1, 2012 | 02:36 PM
FletcherCh's Avatar
C280
Fuse map 1999 MBZ C280
1999 MBZ C280 fuse designation
Under Hood
1 5a beige
Seat adjustment left
Seat adjustment right
Seat heater
2 5a beige
Airbag/sidebag control
*Central locking system
Dome light rear
*Engine residual heat sys
*Heated rear window
*rear head release
*rear trunk release
3 15a blue
*Mirror adjustment right
*Mirrors heater
Radio
*Switch illumination
*Window lift front right
4 5a beige
Airbag fault indicator lamp
*Dome light rear
*Heated rear window
*Rear head release
*rear trunk release
5 20a yellow
Sunblind for rear window
*Window lift rear right
6 7.5a brown
*seat adjustment left
*Seat adjustment right
Telephone
7 7.5a brown
Mirror adjustment left
Rear trunk release
Switch illumination
Telephone
Window lift front left
Window lift rear left
8 30a green
*Dome light rear
Mirrors heater
Switch illumination
9 25a white
Dome light front
Dome light rear
Garage door opener
Make-up mirror
Mirrors automatic dimming
Rain sensor
Switch illumination
Tilting sliding roof
10 15a blue
Radio
*Seat adjustment left
11 20a yellow
Seat heater
12 25a white
Sound sys
13 15a blue
Back-up lamps
Headlight range adjustment
14 5a beige
Parktronic sys
15
16 5a beige
Electronic Stability program
17 30a green
Switch illumination
18
19 10a red
Instrument cluster
Lamp monitoring sys
Stop lamps
20 15a blue
Automatic climate control
21
22 10a red
Head lamp flasher
Head lamp washer sys
Turn signal
Turn signal indicator lamp
Windshield wash / wipe sys
23 15a blue
Cigar lighter
Glove compartment light
24 15a blue
License plate illumination
Parking / tail light right, SMR
25 7.5a brown
Parking / tail light left, SML
26 7.5a brown
Rear fog light
27 15a blue
Steering lock
28
29 30a green
Blower motor (ac)
30 10a red
Instrument cluster
31 15a blue
Low beam right
32 15a blue
Low beam left
33 7.5a brown
Head lamp flasher
High beam right
34 7.5a brown
Head lamp flasher
High beam left
High beam indicating lamp
35 15a blue
Fog lamps
36
37
38 30a green
Engine fan
39
40 10a red Fanfare
41 15a blue
Locking check-back
Fanfare
Hazard warning flasher
Heated rear window
Rain sensor
Rear head release
Turn signal
42 7.5a brown
Heating washer sys
43 10a red
44 40a orange
Rainsensor
45 15a blue
Under Trunk Floor
1 25a white
Fuel pump
2 b5a beige
Anti theft alarm
Convenience locking system
Dome light rear
Engine residual heat system
Rear window heater
Rear headrest release
Remote trunk release
3 30a green
Mirrors heater
Switch illumination
4 40a orange
Anti theft alarm
Dome light rear
Rear window heater
Rear head rest release
5 30a green
Switch illumination
6 5a beige
Dome light rear
Trunk illumination
7 5a Beige
Anti theft alarm
8
Mirrors heater
Switch illumination
9
Dome light rear
10 25a white
11 25a white
12 25a white
13 25a white
