Bulb replacement / Insturment cluster
Old May 18, 2003 | 07:36 PM
msport3's Avatar
1999 C230 Sport Kompressor
Does anyone know how to pull insturment cluster to replace a bulb? Are any special tools needed. The last time I had one go out my mechanic charged me $78.00 for the labor to do it.
Old May 18, 2003 | 08:05 PM
tpliquid's Avatar
too poor now
u need dash cluster pullers. u can get them off ebay. like 20 bux?
Old May 18, 2003 | 08:09 PM
msport3's Avatar
Thanks for the help.
Old Dec 12, 2004 | 06:31 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
That's a rip off for labor, surely they do not take an hour, it should be like ten minutes tops. You can do it yourself, it's very easy and replacing a bulb is like removing a fuse.
Old Dec 12, 2004 | 07:21 AM
maho1975's Avatar
1995 , C220
you dont even need a special tool to pull that out, I have used a coat hanger to pull it out it works just fine..good luck
Old Dec 17, 2004 | 10:28 AM
unctarheels01's Avatar
1997 c280 sport
To do this, do you have to unbolt any bolts. I had the plastic screen in the lower left corner of the cluster fall. I need to get it back on somehow. Anybody know how to do this? I am sure that you can change the guage face color, but I have to get to it... Thanks and sorry for the hijack...
Old Dec 17, 2004 | 01:40 PM
stox's Avatar
'95 S500C, '96 C36, '86 190E, '72 280SEL
FYI. the part number for the Mecedes instrument puller is: 140-589-02-33-00
Old Dec 18, 2004 | 08:58 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
get two coat hangers, make the hook the shape of an "allen key" wrench. insert at 10 o'clock and 2 o'clock then pull back out slowly, you'll feel that the "hook" at the end has latched onto something. It may take a few tries. Once you get the cluster out, there are two connectors in the back, one on the right and the other on the left. They're held down by plastic clamp type holders. They just unclip and the connectors pull out.
no bolts or screws. just take your time and you'll be set.
Old Dec 19, 2004 | 08:53 AM
meanie's Avatar
DO NOT turn the ignition key ON, while the cluster is unplugged.
Old Dec 19, 2004 | 02:20 PM
Public Enemy's Avatar
1998 C 230, 2000 S500, 2002 CLK 430, BMW 525i
Are you changing the colors, or just replacing a dead bulb?
And yes, a hanger works just as good as the "mercedes pullers".
