Climate Problem c220 CDI
Old Jul 5, 2011 | 08:50 AM
darkside25es's Avatar
C220 CDI 1998 Elegance
When i start the engine, the Climate works fine during 1 min + or -, after that the air starts bolwing in ambient temperature, if i stop the engine and restart it again, the cycle restarts, 1 min working fine and after that the air is no longer cold. Another test i made is while the engine is on and the air is blowing ambient air when it should work fine, i removed the fuse number 20 and i put it again the cycle begins again. I don't know what it could be. Yesterday a charged the gas thinking that it will fix it, no way.
Old Jul 15, 2011 | 07:20 AM
When i remove the connector from the climate control unit, the air stops working at all, and when i reconnect it, it works fine for 1 min again. I have changed the Climate Unit control thinking that it can fix it but it did the same.
I'm still searching for the solution
thanks
Old Jul 23, 2011 | 04:17 AM
Solved
It was the evaporator temp sensor, i changet it and it's working fine.
Redouan
