1997 C230 Pre Model Windscreen Constantly Goes
Hi,
At very first, my windscreen wiper went off intermittently.
I looked at the fuse and it looked ok, so I tried swapping it anyway.
The problem went away. Now this new fuse still looks ok, it's not cracked in the middle/burnt. The wiper constantly goes at say... level 1.
It's quite annoying. Especially as it's summer here now lol...
So if it's not the fuse, what's the next step to try, anyone?
Here is a clip of this happening:
http://s757.photobucket.com/albums/x...1-16-30-14.mp4
Thanks :>
Thanks :>
This is commonly caused by a failed combination switch, and you can replace the entire stalk to remedy the issue. Sometimes, it will start affecting the other things controlled by the switch too, such as headlights lights flasher & signaling.
ahhh really? because my right headlight hid bulb went out last week. replaced that, then the left one went out yesterday.
what piece is the stalk? the long actual wiper? motor? everything?
thanks mate
thanks mate
By stalk I mean the combination switch itself, the hand control that you move to operate the wipers, lights, etc. I have read where several owners have done their own, so I believe it to be a fairly simple repair, but I have not done it myself.
The bulbs could actually be coincidence. Light bulbs are built with what's called "built-in obsolescence" which means they are engineered to last a specific number of hours. It the same as if you change all the bulbs in a room at the same time, they will usually go out within a few days of one another after the expected life span.
ok. so I'm looking for something like this?
http://www.ebay.com/itm/Mercedes-W20...item230537ff71
combination switch with stalk correct?
I guess I'll give this a go. did you have a link to directions of disassembling it. then assembling? otherwise I can always google
thanks
thanks
it was the windscreen relay. exact same joint had a crack in it. I went out and bought a solder iron, solder and put it back to a nice round circle, ensuring there were no cracks/holes anywhere.
problem fixed. windscreen wiper doesn't constantly go anymore. goes when I want it too
the rear window heat sensors had no cracked joints so need to look other things for that.
