How to replace the spark plug?
Old Jun 11, 2003 | 06:46 PM
tseinsf's Avatar
1999 C-230 Sport
Hi all,
I’m new in this forum. I just picked up a 1999 C-230k and it’s has a 63k miles on it. I would like to do some maintenance and replace the all spark plug. If I order this from WWW.bmaautopart . Do I need to do any gap adjustment on the spark plug before I replace? I would also like to drain the brake fluid. What is the procedure? Any suggestion will be appreciated.
Thanks in advance..
1999 C230 Kompressor Sport
2002 Toyota Camry
Old Jun 11, 2003 | 07:06 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Hi,
I don't know about the spark plugs, but the brake fluid is a small plastic tank, in the engine bay, up against the steering column. If your facing the engine, look up to the right corner, and it should be like a goldish/yellowish fluid there. That's your brake fluid.
Old Jun 12, 2003 | 02:34 AM
DougandhisC280's Avatar
2008 SLK-280
If you get OEM spark plugs the gap should already be set for you. Just follow the spark plug wires to the plugs. Pull off the wire, unscrew the plug and put in the new one. As far as brake flood goes that is something that you should have a professional do or at least do it with someone who has done it before. It is a 2 person process because one person has to step on the brake pedal while the other is opening and closing the valve on each caliper. It's not hard to do but if you mess up you could get air in the brake lines which will cause major problems in the future. When you go to change the fluid I recommend Valvoline SynPower Dot 3 brake fluid.
Old Jun 12, 2003 | 04:02 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: How to replace the spark plug?
Welcome to the forum.
Why do you want to drain the brake fluid? Your car needs brake fluid or it won't stop.
-s-
Old Jun 12, 2003 | 10:51 AM
2008 SLK-280
Haven't you heard of air brakes?
Old Jun 12, 2003 | 10:55 AM
Rincewind's Avatar
1998 C230
is that where the car infront of you (or tree) stops the car?
Old Jun 12, 2003 | 07:59 PM
KurumaGOD's Avatar
Air brakes...sure...just takes longer braking distance to stop the car thats all...
Old Jun 12, 2003 | 10:51 PM
tpliquid's Avatar
too poor now
he is talking abuot the air brakes that kit in knight rider has. stops car from 200mph to 0 in like .2 seconds
Old Jun 13, 2003 | 12:43 AM
aroppi's Avatar
1994 C280
about spark plugs, U can do it by yourself but make sure to tide the plugs properly. not too loose but not too tide. use a torque wrench would be better and check the torque spec of the spark plugs.
about brake fluid, i don't recommend to do it by yourself if U don't know how to do so. "air-brake" could be a fatal problem!!!!!!!
i think we should use DOT 4 brake fluid for a modern MB. but make sure to flush it clean. DOT 3 can't mix with DOT 4!!!!
Old Jun 13, 2003 | 12:56 AM
2008 SLK-280
I think he means "tight" no tide. They make dot 4?
Old Jun 13, 2003 | 03:31 AM
scorchie's Avatar
Who are "they"?
Lots of companies make DOT 3, DOT 4, DOT 5, DOT 5.1 ... and YES, you can mix DOT 3 and DOT 4. Also DOT 3/4 can mix with DOT 5.1. The only odd one out of the bunch is DOT 5, don't mix with anything. Don't even put it in anything. Well that is unless your car originally came with DOT 5, and I don't know of any MBZs that did.
BTW, the requirements are DOT 3 I believe. I usually use DOT 4 or 5.1 though, it gives a higher boiling temperature.
-s-
Old Jun 13, 2003 | 10:25 AM
2008 SLK-280
Who are "they"?
THEY are the brake fluid manufacturers. Stop giving me a hard time.
Old Jun 13, 2003 | 11:13 AM
aroppi's Avatar
1994 C280
Oops!!! sorry!! it should be "tight".
by the way, my C280 use DOT 4 brake fluid and it's GOOD!!!
Old Jun 13, 2003 | 01:30 PM
scorchie's Avatar
Oh, then no. Brake fluid manufacturers don't make DOT 4. Only the government.
-s-
Old Jun 17, 2003 | 05:50 PM
HYPERI0N24's Avatar
C220
I'm still waiting for TP to share his experience in regards to the brakes
Old Jun 17, 2003 | 05:55 PM
tpliquid's Avatar
too poor now
yea...if u use ghetto style pump brake pedal to bleed brakes..bad idea...
my dad and i did that..and look what happened...master cylender is broken. only front brakes work..rear brakes have liek .01% power ....
Old Jun 17, 2003 | 06:18 PM
2008 SLK-280
You should've been more carefull.
