Startup problems
Old Jun 11, 2003 | 07:03 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Startup problems
Once in a while, when I start my car, it will start up, start shaking then die. The RPM needle will go above 500RPM's, then drop then die. Anyone know why this happens?
My dad thinks its the air to fuel mixture ratio, maybe not getting enough of something? Cuz it's not the battery, pretty sure of that. Thanks!
Old Jun 12, 2003 | 02:36 AM
DougandhisC280's Avatar
2008 SLK-280
Sounds like another case of a MAS meter starting to go out. I sure hope you have some cash on hand.
Old Jun 12, 2003 | 10:47 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Great...will it give me warning when it's totally gone? like CE light comes on or something? I don't feel like dropping that kinda cash right now if it's still working, try to hold out till it dies maybe?
How much is it? $600?
Old Jun 12, 2003 | 10:56 AM
2008 SLK-280
No, I think it's like $280 but dealers like to charge 3 hours labor for the five minutes it takes to install it. I have the receipt still. It really says 3 hours labor and diagnostics on it. I should have just replaced it myself and then taken it in to Autozone to get the check engine light reset.
It may not be the MAS meter on yours. I'm just giving you an idea of what it could be. It could also be the IAT sensor.
Old Jun 12, 2003 | 11:46 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
So most likely it's a sensor somewhere going bad...
Old Jun 15, 2003 | 02:25 AM
chykneestweakr's Avatar
do you still have this problem? did you ever get it fixed? i have this same problem but it only happens once in awhile....please help.
Old Jun 15, 2003 | 11:21 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
This problem only happens once in a while as well. I called my service advisor, but he was on vacation. He should be back next week, so I'll call again to get an appointment to get it checked out. Let you know what they find out.
Old Jun 17, 2003 | 11:21 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Since the last time I posted, the starting problem never arose until tonight. I started the car and it was idling below 500 RPMs...but didn't die this time. It just kept hovering below 500, sounding like it was about to die. I thought the problem went away!
Old Jun 20, 2003 | 09:26 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Called the dealership...my advisor said it is probably the airflow sensor due to the mileage on the car..126,000. Anyone know how much this will cost?
Old Jun 20, 2003 | 09:39 AM
Rincewind's Avatar
1998 C230
part is 200 bux or so
dealer will charge you upwards of 600+
Old Jun 20, 2003 | 09:41 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
bah...another hit to da wallet
Old Jun 24, 2003 | 01:25 AM
aKaKonG Ric3r's Avatar
Gary-Fisher by BenZ
Talking
everyone that owns a damn C w202 is re-taa-ted, come on cheapo's..get a real car, like a rice rocket fisher.. now that thing hauls assssss! hook up a nice intercooler in that gerry and you'll be whoopin them m3's asses, no sweat
Old Jun 24, 2003 | 06:26 AM
N.M.M.'s Avatar
had that problem before...
I had that problem before on my c280, it would have a hard time starting, hesitation and so on. we replas the mas, the throttle actuator and it turned out to be the fule pressure regulator. its really easy to check if it is bad. just pull off the vaccum tube connected to the fpr and check for gas if the is gas there it is bad. easy $40 replacement. try it out. if its your throttle actuator i have an extra one for sale dealer charges 1200+ give me an email.
Old Jun 24, 2003 | 05:08 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Apparently, my service advisor told me that it is a O2 sensor going bad, thus producing the problem. Tho, no CE light came on? isn't the CE light suppose to come on if the O2 sensor goes?
