advice on a Mystery
Old Jun 18, 2003 | 06:40 PM
jimsaco's Avatar
advice on a Mystery
Hi all -- 3 months into my '96 C220 and generally very pleased. But something has come up...
I got the oil changed last week, and as I drove off, the "low coolant" warning light came on and has stayed on since. I checked the coolant level; it is full. (How long it's been since the system was flushed I cannot tell you.) The car does not seem to be over heating; the temperature gauge is just above the 80 mark.
Advice? Is it possible the guy who did the oil change jostled some sensor loose? Thanks in advance. -Jim
P.S. I would like to do the oil change myself. How can I get the tool/wrench needed to remove the filter housing?
Old Jun 18, 2003 | 06:59 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Jim, I'm not familier with your particular car... but on one of my cars, the coolant sensor goes in through the cap of the overflow bottle. This can come loose and give me a "low coolant" warning, as well as if the connector comes off the cap. You may want to try seeing if anything is loose in that area.
-s-
Old Jun 18, 2003 | 09:07 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Filter Housing Wrench
I purchased a stamped steel "socket" that fits the 14 sided filter top from an auto supply store on LI. I believe I measured the size of the filter housing and picked out a "socket" that fit. They also had a sizing guide that happend to match what I had picked out any way.
These type of fiter tops are popular in newer cars and I would expect most auto supply stores would carry them.
Old Jun 18, 2003 | 11:03 PM
Faheem Daddy's Avatar
w202 C220
I also have a 1994 C220...
I just had a recent major service done on it through a local Mercedes-Benz dealer, and they changed/flushed all the fluids on the car. Since then, it looks as though my car has been leaking coolant. This all came to my attention just this week.
I got in the car on Monday morning, and I saw that the coolant light came on...when I checked the coolant...it was full. Now, whenever I park the car somewhere, I notice that it leaks coolant under the car...but when I drive off, the temp gauge stays constant, and the coolant level is full...and I'm sure that it in fact is coolant that's leaking, not anything else. I'm sorry if any of this is hard to understand, but this is my situation, and its pretty ironic to see you in the same predicament. Anyone have any suggestions of how to fix this?
Old Jun 19, 2003 | 03:42 PM
DougandhisC280's Avatar
2008 SLK-280
All right! A fraternity boy on the forum!
