Car not shifting till i let off throttle??Help??
C230 kompressor
ok so my wife hit a possum the check engine lights been on so i got the computer read its throwing a code for the supercharger and the maf now the tube that goes from port at the front of the hoodto the airbox was cut in half i taped it up also the plastic end of the intercooler under the car has a hole in it so i taped it up also to see if it made a difference the check engine light is still on the car spools i can hear it but if i dont let go of the gas it wont ****ft itll take me past redline. would the maf being bad cause something like this it idles rough sometimes but doesnt stall and doesnt do it often is there a way to reset the check engine light to see if it throws the same code? I work on muscle cars lol i need some insight thanks!!
2000 c230 1996 c280 1994 c280
What exactly are the codes?
If your MAF is bad or dirty, it can cause what you describe. Try cleaning it with MAF cleaner. If that fails, you may need a new one. Don't get a cheap one.
