Transmission fluid for W202, 722.6 - what should i get? fuchs or Shell 134?
or
Pennzoil Auto Transmission Fluid Shell 134 for Sprinter - 5080660 (for almost half the price of Fuchs?)
Also? How much do i need? 8-12,14qt? Will drop the pan to fix p0715 and p0720 codes
Hope this helps.
BobR
Check this thread out...good factual information: https://mbworld.org/forums/clk-class...ight=722.6+ATF
After searching for M-B ATF with no luck, I opted for Shell 134 ATF. According to the package and confirmed by Shell Technical, it is compatible and approved for 236.10, 12 and 14 specs as well as NAG I to V standard.(reference Star Bulletin dated Aug. 13, 2008, Order S-8-00 40/89 as well as "Operating Fluids M-B extranet; 236.14 Automatic transmission fluids (ATF, Specification 236.14, updated 1/09/2012") It is M-B approved for factory fill.
The list also includes several other options such as:
FUCHS Titan ATF 4134
M-B 236.14 ATF, A 001 989 68 03
Mercedes-Benz Automatik Get... Blatl 236.14
Mobil ATF 134
OMV ATF M plus
QB AUTO 25
Shell ATF 134
Shell SPIRAX S6 ATF 134M
TUTELA TRANSMISSION STARFLUID 7S
I chose Shell because of availability, compatibility and the technical information. Hope this helps anyone that is wondering what ATF is best for your 722.6.
