Help With 2000 C280 PLEASE
Old Mar 22, 2012 | 06:13 PM
oceanside182's Avatar
2001 c280
Hi Im totally new hear BUt have had this problem before.
Payed Tow Company to bring it to shop and shop called in 15 minutes Problem Solved.
Im hoping you can help.
I accidentally hit the "TOW BUTTON " on dash and problem started .
After speaking with many they all said the tow button ONLY disengages alarm for towing purposes.
The car would not go in gear. It was locked in park. After doing the whole pushing pin down in gear shift with pen we were able to put it in drive . While car is in drive it is stuck in low gear and wont shift into high gear.
We tried to reset car by disconnecting battery,
Im completely lost.
I know its a simple fix to someone who has knowledge of Mercedes cars.
After problem I had exclamation point in center of dash and had a problem starting it, Afer finally getting started I am left with a solid block where it should say D for drive.
Thankyopu SO much
