C220-94 Stalling and not starting properly
Old 05-07-2012, 04:28 PM
trexgarth's Avatar
c220
Well, been reading this forum for a long time trying to get info for my problems, and have now reached the point to not know what to do It's time to ask for help......
This is my story:
Bought a C220 -94 with 220.000 km on the meter. Car functions well for a while, then I get a misfire, cured with a restart. After some days the car suddenly stalls, as in engine shuts off, restarts after several attempts. Cannot trust the car any more as it randomly stalls/shuts down. Beginning to scout the internet finding this excellent forum.
What I have done so far:
1. Changed spark plugs (seemed to fix it, the car worked for a day and then NOT).
2. Fuel filter & Fuel relay (same as above)
3. Crank & Cam shaft sensors (car is working for some days and start to behave as earlier)
4. OVP relay (same)
5. MAF (same)
Car is now not even function any more, when cranking the engine it's starting for a split second and then dies. I can keep it going by flipping the ignition key repeatedly.
After several attempts to start it suddenly cranks and idles for a minute or two and then stops, trying to start again, with success. Engine runs for 10 min and suddenly starts to misfire, shutting down and restart. Run for 8 min and start to misfire again, and we are back to "starts for a split second and then dies".
I got the car scanned with the result of over 15 errors all from ground issues, Lambda to MAF sensor. Start to clean and reconnect all ground points. Didn't make any difference.
Start to suspect wiring harness... And yes it crumpling to pieces, sad
But YEAH fund it!
6. Begin to rewire the harness and try to start the car..... same as earlier, cranks for a split second and dies.
Cut the throttle actuator cable open and yes, cables is degraded, rewire all the way in. Test... didn't make any difference.
Does anybody have the ohm readings for healthy ignition coils so that I can check them??
Regards T. Garth
Old 06-17-2012, 05:54 AM
trexgarth's Avatar
c220
bump some one??
Old 06-25-2012, 12:37 PM
taz069's Avatar
chevrolet z-71
Man I do wish i could offer some assitance in your situation. Do not give up for sure and check into club 202!! They are geared for the w202 cars!! I left this room long ago just to find that the club 202 is awsome for our cars. Hope you can find some answers their!!
Old 07-31-2012, 12:59 AM
C220_Lizz's Avatar
1995 C220
judging by experience there are wires somewhere that could still be causing a problem or position sensor/ CKP sensor..
Old 08-03-2012, 06:19 AM
trexgarth's Avatar
c220
update
Have got indications on a immobilizer problem from a friend mechanic. Didn't know that there was such a thing on this car. There was a after market anti theft system with a type of chip that should be inserted in a slot before it would start, this system caused a lot of aggravation when after repeatedly "insertions" finally let me start the car, so I bypassed it with success. This was before I got problem stated earlier in post!
So..... how to fix MB immobilizer?
Old 03-18-2019, 11:22 AM
PaulIMBenson's Avatar
mercedes c280 1996
Angry Mercedes C280 1996
I have the same problem and they say the CKP module is killing the fuel injectors as a part of its security job. If it does not publish a signal the car runs 3 seconds as a result of the PCM Powertrain control module and then dies because the CKP kills it. The manufacturer will sell the new module for $2500 but the car is beautiful but not worth fixing for that price. ANY suggestions? What did you do to fix the C220? Helppppp?
Quick Reply: C220-94 Stalling and not starting properly
