H&R Cup Kit?
Old Jul 26, 2003 | 09:16 PM
Brandon24C's Avatar
2000 C28 Sport
H&R Cup Kit?
Hi, I am new here and I want to lower my 2000 280 sport. What are your opinions on the H&R Cup Kit? Im putting 18's on the car and I want the wheel well to hit the tire dead on. Any suggestions? Also, does anyone know where you can get the carbon fiber steering wheel for the 202? I checked brabus.com but could not find it. Thanks for the help!
Old Jul 27, 2003 | 12:18 AM
tpliquid's Avatar
too poor now
contact Mbenznl (steve) he can get u those cf steering wheels.
cup kit is low
the wheel well deftinally hit the wheel fo sho! rub a rub a dub dub rubbing fo sheazy
Old Jul 27, 2003 | 07:25 AM
Brandon24C's Avatar
2000 C28 Sport
Hey, thanks for responding. Can I get the cup kit and not have the wheels rub without rolling my fenders? What would you recomend? I want the cup kit but I don't want it to rub. Thanks for the help.
Old Jul 27, 2003 | 07:32 AM
Brandon24C's Avatar
2000 C28 Sport
Also, will the cup kit be ok if I put on bigger pads. Do you know how the ride quality is with the cup kit? Thanks for the help TP and anyone else who has an opinion!
Old Jul 27, 2003 | 05:24 PM
Brandon24C's Avatar
2000 C28 Sport
Unhappy
Sorry to press this subject further but my car is going in tomorrow and any immediate input would help tremendously.
Old Jul 27, 2003 | 08:26 PM
tpliquid's Avatar
too poor now
cup kit with thicker pads will rub on full u turns.. i think thtat is problem david is having with his acr. he said ride quality is not bad
Old Jul 27, 2003 | 10:47 PM
Brandon24C's Avatar
2000 C28 Sport
Thanks for the help. With that known, what would you suggest as the best setup. I want the car to sit as low as possible without rubbing. Im probably going to go 225/40/18 all around. Thanks!
Old Jul 27, 2003 | 11:05 PM
DougandhisC280's Avatar
2008 SLK-280
You can get more versatility with a good sport spring/ sport shock combination. That's what I have and here is what the height looks like.
Old Jul 27, 2003 | 11:11 PM
Brandon24C's Avatar
2000 C28 Sport
Thanks Doug. What setup do you have? Do you have any other pics. What would you recommend to have the tire perfectly touch the top of the wheel well? Is that possible to have without any rubbing? Thank you for the help. I know im asking a lot, but I want to get it done right. Thanks!
Old Jul 27, 2003 | 11:41 PM
2008 SLK-280
I have 18 by 8 all around. Carlsson Springs and Bilstein Sport Shocks. If I lowered the car another 1/4 of an inch I would definately rub when I turned. Right now I only rub if I hit a huge bump while turned hard. I just think the H&R cup kit would rub like crazy with 18's.
Old Jul 28, 2003 | 12:51 PM
amgc230k's Avatar
Hi I have the cupkit on my 99 c230K and i regret the fact of buying it because the car sits really low I had to roll my front fenders and i still rub when i bust u turns or hit hard bumps so i suggest you not buying the cupkit and just go with the regular H&R sport springs with bilstein shocks thats just my 2 cents....good luck
Old Jul 28, 2003 | 12:55 PM
smoothb's Avatar
2003 C320
doug
How do you like those rims? I'm thinking about buying a set.
Old Jul 28, 2003 | 05:01 PM
Brandon24C's Avatar
2000 C28 Sport
Hey AMG230K, thanks for responding. One question though, what number pads do you have on your car in the front and the back. Have you tried going to a thicker pad?
Old Jul 29, 2003 | 12:37 PM
2008 SLK-280
I love them. The center caps are really cheap so be careful with them. The pictures don't do justice for them. The wheels look so much better in person.
Brandon 24C: Here are front and back pictures of my ride height. To save from any confusion I have my stock wheels and tires on right now because I have been traveling. The 18's will be back on in a couple weeks. Just a reminder, I have Carlsson Springs and Bilstein Sport Shocks. I don't remember the pad size but I want to say 3 in front and 3 in back.
Old Jul 29, 2003 | 12:38 PM
2008 SLK-280
Old Jul 29, 2003 | 12:39 PM
2008 SLK-280
Old Jul 29, 2003 | 09:31 PM
Brandon24C's Avatar
2000 C28 Sport
Thank you for the pictures Doug, that helps a lot! The lowering job in the back looks exactly like what I want in the back. One more question, if I was willing to roll my fenders in the front, do you think that the cup kit would work? Thanks for the help!
Old Jul 29, 2003 | 10:46 PM
2008 SLK-280
Maybe but you will probably have problems in other areas. I have never heard of good results out of a cup kit on a Mercedes. Every one else on this board that has suspension work done has springs and shocks and have no problems. (except for henry because he has 19's) I would just go with Brabus or something. I see them on ebay frequently.
Old Jul 30, 2003 | 06:49 PM
amgc230k's Avatar
to your qestion brandon yes I am using the highest spring pad available for the front i think its a 5 but as for the rear im also using the highest available also the rear doesnt have any problems im running 18X8 all around but as for the front you definatley need to get your front fenders rolled and still you have a problem with tire rubbing only on full u turns and on hard bumps.....DO NOT GET THE CUP KIT......Im trying to get rid of mine...LOL
Old Jul 30, 2003 | 08:51 PM
2008 SLK-280
Couldn't have said it any better.
Old Jul 30, 2003 | 09:18 PM
Brandon24C's Avatar
2000 C28 Sport
Thank you for the help, I appreciate it!
