The dreaded window/mirror issue
Old Nov 17, 2012 | 03:49 PM
impromento's Avatar
C200 Classic Auto S-98
Smile The dreaded window/mirror issue
Hello all - im brand new to the forum - so apologies for any errors in my post
recently fixed the common brake light switch issue which sorted out the cruise control and the dash asr/bas light _ happy days
but today, the passenger electric window and mirrow have stopped working - copletely dead.
and to top it off - on the way to the garage this evening i realised that the outside temp display is not lit either
Loads of searching the web has brought up a range of different causes/fixes for the window and mirror problem - but i wondered if anyone had any views or fixes that the think is best - and is there a chance the 3 could be linked?
i havent tried anything yet, thought i would start here!!!
it all worked fine two days ago aswell! typical...
many thanks
Old Nov 17, 2012 | 11:12 PM
jc1kz's Avatar
2014 C259 Sport MB White Diamond Pearl
I don't know about the window and mirror, but my temp went out, so I bought a new cluster thinking (or not thinking) it was broken, but it turned out to be a burned out bulb that needed to be changed.....while I had the cluster removed I replaced all the bulbs at once so as not to have to remove the gauge cluster again. So the temp needs a new light in back of the cluster changed....
Old Nov 18, 2012 | 06:38 AM
impromento's Avatar
thanks jc1kz - i'll look into how much of a job getting to the bulbs is - i cant imagine its a simple one!
Old Nov 18, 2012 | 06:57 PM
jc1kz's Avatar
Here are several ways to remove the cluster on youtube.com good luck....
http://www.youtube.com/results?searc....1.lpfNo19wANU
Old Nov 18, 2012 | 10:51 PM
BMWguy325is's Avatar
None Yet!
If you remove the underdash panel or knee bolster thing you can get to the bulbs in the back of the dash.
