Worked over by a Reindeer....
98 C230
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
![Worked over by a Reindeer....-0mjigl.jpg](https://mbworld.org/forums/attachments/c-class-w202/446421d1683254995t-worked-over-reindeer-0mjigl.jpg)
This is the current state of my 98 C230. Just happened 3 hours ago from a run-in with a deer.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
I was thinking of purchasing a OEM hood or maybe Carbon fiber....Next I will assess the Radiator damage and buy a new one if needed. Most likely the radiator mount should still be ok and hopefully the Fan wasnt damaged too much.
In a way I look forward to rebuilding the front end of this car and would like any input from the community available.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
GrumpleStache
2014 C259 Sport MB White Diamond Pearl
Holly F&^%ing SH#t.... Man that was one bad *** reindeer...
Glad you are okay...I would fix it
Of course insurane will want to total it, if they do buy it back and fix it, hmmm....new headlights/bottom headlight trim piece/cornerlights/rad core support/new radiator/hood/grill/new fan...and thats just the big stuff, anyway a body shp will give you a list of things that need fixing.....Good luck....
98 C230
Thanks for the input. Yeah it was a pretty big deer. In fact I think it got up and ran away.
The big stuff should be no problem to find online and surprisingly the headlight assembly on the passengers side is unharmed. I will be doing most of the work myself so if you have other suggestions for upgrades that would be awesome.
The front end will be in pieces most of the holiday season so i might as well do some work on the error code it also throws off. (p0442 fuel vapor leak in the EVAP control system.)
anyway back to work for me. ill probably spend the day excited to tear the front end down when i get home.
