my battery dies overnight?
w202 c class
my battery dies overnight...my keyless entry cant work so i cant access my battery in the trunk for a jumpstart. without access to the battery how else can i jumpstart my car or atleast open the car's central lock system and get access to the trunk? the battery boys tested my battery and told me it was fine so ultimately what could be the problem? please help
Posted from Mbworld.org App for Android
w202 c class
my metal key broke at some point and it had to be welded back in place...it can now only work in the ignition and the co driver's door
The only way to figure out what drains your battery is to have the battery charged up. So thats where I would start.
Designo AMG
There should be posts up front to jump the vehicle as well. But yea, I would get a spare key anyways. Anything after market installed that is causing a drain? Also, depending on how old the battery is you might want to just replace it.
10 C63/p31, 84 190/5.8L, 14 Audi Q5 TDI, 03 Suburban /8.1, 87 Porsche 944/358" 77 Ferrari 308 Dino
Had a friend that had another German car BXX that he would take to the airport and be gone a few days. When he returned, the battery was always dead. After spending much time and $$ he found that the trunk light was never turning off. So check that and your glove box also. It could also be a defective diode in your alternator causing the short.
Good Luck.....
Good Luck.....
