Headlight switch removal 2000 C230K
Old Dec 31, 2012 | 08:16 PM
earld's Avatar
2001 E430, 1999 SLK230
How do I remove the headlight switch on a 2000 C230 ? Mine is failing to turn lights off all the time. Switch is a bit loose
Old Jan 3, 2013 | 04:09 PM
buzzk1ll's Avatar
From: In the spare room in the castle the Mouse has allowed me
1996 C220
Make sure the plate that covers the the underside of the dash is off.
The pull knob off, should see a large flat nut. I used needle nose pliers to start then spun it off by hand. I had to pull the e-brake release forward and remove to screws. Dropped it out from the back.
Hope this helps. YMMV
