error code 25 for 2000 c230 kompressor
Old Jan 7, 2013 | 10:08 AM
Lorenzo2030's Avatar
Can anyone tell me what error code 25 is on a 230 kompressor yr 2000
there's a small clock and wrench that appears as soon as a turn the engine on than it goes to an odemeter reading. Appreciate any insights what it is and how to fix it, Thank you
Old Jan 10, 2013 | 11:45 AM
Seems it's a regular maintenance reminder of some sort the little clock and than wrench is behind the odometer -shows up when i first start the car...the code has changed from 28 to 25 to 23. anyone see this before?? txs
Old Jan 12, 2013 | 09:41 AM
rostrom's Avatar
2013 ML350, 2006 SLK280
I think this is the Camshaft Position Timing - Over-Retarded code. This is often just the sensor gone bad, but it could also require magnets. The wrench code is simply your flexible service reminder, meaning it is time for at least an oil change.
Most error codes are listed here:
https://mbworld.org/forums/c32-amg-c...ror-codes.html
