Classic C180 Accleration
1997 C180 Classic
Hi All,
Hoping you can lend some insight into an issue I seem to be facing.
Purchased a 1997 C180 classic a few months ago and converted to MB's!
Starting to get a feel for the car and noticing some niggling problems. Apart from a CAN BUS issue im trying to get to the bottom of, I am getting a very odd acceleration issue. Im not sure if it is jsut how the car behaves or if it is something clogged/blocked or in need of replacing.
When I accelerate, in every gear apart from first (and at high speeds above 50 mph) the vehicle accelerates smoothly, then seems to stop accelerating, then resumes accelerating again. This happens at every pedal position, even kickdown. Whats wierd is that this doesnt happen when accelerating via the cruise control stick.
Im hoping that this is whats causing me to get 300 miles max out of a tank of petrol...![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Any advice/insight would be massively appreciated.
Cheers all!
Cheers all!
Cheers all!
