99 230 Kompressor fault codes
Old Feb 8, 2013 | 05:21 PM
matttttttt's Avatar
C230K
Unhappy 99 230 Kompressor fault codes
Hi,
Check engine light came on and my wife said the car was roaring and move slowly(in high RPM). I assume the car was in limp mode. Fault code pulled-
P0720(output Speed sensor)
p1747(Electric Gear Selection module)
P0130(Bank 1 sensor)(O2?)
Cleared the codes and this morning same limp mode problem occurred after a fe days, but no check engine light. She pulled over and put gear back to P and moved from P to D and the cars runs fine again.
Any advice what could be wrong? The car has about 85K miles only.
Thanks!
dave
