knocking from front end
Old Feb 28, 2013 | 01:08 PM
foxydog's Avatar
1994 w202
hi i have a knock on the front end i have already replaced uper and lower ball joints made no difference track rod ends are ok no movment on wheel bearings i am at a loss only things i havent checked are the idel arm bush which i replace 4 years ago and the steering drag link but its passed 2 mot,s with this knocking thanks for any replys
Old Mar 7, 2013 | 07:56 PM
Dino X's Avatar
1994 MB C220
Hmmm…. Go back again to idle arm bushes or does the knock is more audible when you use your brakes? Try checking on the disk brakes carriers for loose bolts and snap pins. it can also be the gas type worn-out shock absorbers…
Old Mar 12, 2013 | 04:00 PM
97C28O's Avatar
center drag link /tie rod linkage
Old Apr 6, 2013 | 09:09 AM
The Gunny's Avatar
1998 c280
Front End
Does it knock when turning left or right, or when going over a bump? Mine made some noise when going over bumps at slow speed and it turned out to be worn shocks. Replaced those and upper ball joints, back to normal.
