98 C230 Dim battery light
Old Mar 14, 2013 | 02:44 PM
Battosaii's Avatar
98 c230
my 98 c230 (US version) had a dim battery light before and was not charging so i ordered a voltage regulator and it fixed the problem but now about 2 months later the dim battery light came back on.
so here is whats happening the light turns off sometimes while i drive but it always comes back on again and its so dim you ban barely see it in daytime so far i have checked the cabled to the alternator and they are nice and tight and everytime i check the voltage with my Multimeter the voltage is around 13.7v and its super stable it dosnt move much even with my subwoofer going.
im not sure what it could be because the car is charging and 13.7v is quite normal for most cars but a battery light does scare me a bit i dont want to be left stranded.
i was thinking of just buying a new bosche 115 amp alternator but i dont know if it will fix the problem
Old Mar 14, 2013 | 05:17 PM
Battosaii's Avatar
98 c230
well i pulled the cluster out and i used my multimeter to measure the contacts for the battery light, well with the key in the ON position the contacts get 12v wich is normal becuase all lights turn on for a few seconds when you put the key in the on position, then i started the car and the voltage on the contacts was 2.1v making the battery light come on dimly i dont know what would make it do this.
