W202 C230 Kompressor Service
Gong to do a full service to the car this year, just going to post what I'm going may or may not have done so far.
Headlamp bulbs uprated H7 (Set) # 000-998-00-07
Oil Service (Mobil-1)
Oil Filter # 104-180-01-09
Trans Oil Service (MB Trans Fluid)
Trans Filter # 140-277-00-95
Trans Seal # 140-271-00-80
Trans seal ring # 140-271-00-60
Trans screw plug # 000-997-65-32
Dust Filter # 210-830-12-18
Intake Filter # 604-094-14-04
Fuel Filter # 004-477-28-01
Valve cover gasket #111-016-09-21
Alternator REMAN # 010-154-47-02-88 (DONE)
Spark plugs x4 # 003-159-78-03
Spark plug cable x2 # 000-159-36-42
Spark plug coil x2 # 000-158-75-03
Spark plug coil plug x2 # 000-159-38-42
Spark plug cable x2 # 110-159-18-18
Spark plug cable sleeve x4 # 000-159-14-38
Suppressor plug x2 # 000-156-75-10
Oil level sensor # 124-542-00-17
Oil level sensor seal # 015-997-39-48
Pressure sensor # 011-542-06-17
Engine temp sensor # 005-153-63-28
Engine temp sensor seal # 007603-014100
Camshaft Position sensor # 004-153-00-28
Engine knock sensor # 003-153-89-28
Crankshaft Position sensor # 003-153-28-28
Crankshaft Position sensor seal # 104-997-00-48
V-belt Kompressor # 011-997-58-92
V-belt Engine # 011-997-02-92
P/S Pump pulley # 111-230-00-15
P/S Pump pulley screw # 007-990-08-01
Tightener Pulley # 111-202-01-19
Tightener Pulley screw # 000912-008025
Belt Tightener pulley # 119-200-14-70
Belt Tightener pulley screw # 910143-008021
Belt Tightener # 111-200-13-70
Belt Tightener screw # 910143-008002
Belt Tightener # 111-200-07-70
Belt Tightener pulley # 111-200-00-70
Belt Tightener pulley nut # 111-990-00-53
Belt Tightener shock # 111-200-04-14
Mass Air Flow Sensor # 000-094-09-48
Water pump pulley # 111-202-04-10
Water pump pulley screw x4 # 910105-006007
Water pump pulley washer x4 # 000125-006449
Water pump # 111-200-23-01
Thermostat # 111-200-12-15
Thermostat seal ring # 021-997-07-48
Fan drive # 111-200-04-22
Fan blade # 603-200-02-53
Fan blade screw x3 # 914020-006017
Brake Pads front # 004-420-02-20
Brake Rotors front x2 # 210-421-07-12
Brake Wear sensor x2 # 202-540-07-17
Brake Pads rear # 004-420-91-20
Brake Rotors rear # 203-423-01-12
Very comprehensive list.
Did a some of the same things when I acquired my 2000 model, though nowhere nearly as comprehensive as yours.
Perhaps I missed it, but do you have changing the oil in the Supercharger in there?
The supercharger is an Eaton M62, and although you could get some overpriced oil for it from Mercedes, I got mine from GM, as they use the same supercharger in some of their models, takes the same oil recommended by Eaton it is significantly less costly through GM.
Was not hard to do. Once the airbox was removed, then remove a bolt, suck out the oil, refill.
Paul
Paul
Wait really? Never heard of such thong... What kind of oil does it take again? Don't think I have ever done that, think though.
It has been about 2 years since I did it. Was pretty easy.
If you have done all that other stuff, this will be one of the easiest things.
I had to remove the entire air intake box, then you can see the supercharger.
At the bottom, there is a bolt that accesses the oil port.
I just unscrewed it, sucked out the old, and refilled with GM part number 12345982
Look around on line for videos for changing the Eaton M62 oil, you will see several. Mostly Pontiac. Same unit, just a different adapter housing.
When working on mine, I found one with decent photos for the M111.975 engine, but I could not find it today quickly.
I will be changing it again this summer. It is easy, cheap and why not.
Paul
Paul
