tranny different
Old Aug 26, 2003 | 11:41 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
tranny different
hey all,
Usually when you first start up the car in the morning or after a long period of rest for your car, the tranny takes longer to upshift to warm up the cat converter so that it works more efficiently for less emissions. But the past two days, it doesn't hold the gear longer anymore...it just upshifts as if it is already warmed up...but it isn't.
The first occasion, it was sitting outside for more than a day without it being driven and it just shifted normally. Is that normal because of the warm weather? (but it hasn't happened before when it was like 100 degrees outside)...anyone shed some light on this one?
Thanks, G.
Old Aug 27, 2003 | 08:07 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
anyone? plz
Old Aug 27, 2003 | 11:34 AM
DougandhisC280's Avatar
2008 SLK-280
Thermometer Sensor in cat????? Hot weather???? I don't know, I'm just responding like you asked.
Old Aug 27, 2003 | 12:52 PM
cil254's Avatar
C220
I had the same problem on my 94 C220.
There's a vacuum part that delays the shifting. It's called the upshift delay valve or something like this. It's a plastic box with cables. It might need to be replaced.
Old Aug 27, 2003 | 08:31 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
will it cause damage if it's doing what's its doing now...will my emissions be worse than b4?
Old Aug 27, 2003 | 08:32 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
oh, and how much did it cost ya to get that fixed? gonna be poor after this friday's repair on my car.
Old Aug 27, 2003 | 09:40 PM
benzdude280's Avatar
C280
I agree with cil254. Had mine replaced, but it was still under warranty so I can't help you out pricewise. Good luck!
Old Aug 27, 2003 | 10:57 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
were the symptom the same? Will it cause the tranny or cat converter any damage if it's not fixed immediately or CEL light come on? Thanks for u'r help.
Old Aug 27, 2003 | 11:08 PM
C280
well to tell you the truth they ended up changing the whole tranny out and putting a new one in, so I think in the long run it will ruin the tranny. Sorry to bring bad news.
Old Aug 27, 2003 | 11:10 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
DAMN...that really sux. Maybe I should just drive it till it gives me more sign of trouble, as it has 129,000 miles on it currently? This could just be a fluke, hopefully.
Old Aug 28, 2003 | 12:34 AM
DMXtremeZ's Avatar
2013 Audi S4
my tranny's been acting weird today - it hit the limiter today on first and bounced once before shifting for some reason... im thinking new transmission fluid?
Old Aug 28, 2003 | 09:10 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
possibly.
Benzdude, do you think that the tranny may need a fluid flush, maybe thats causing the problem?
