those with pre-97 w202's
'05 A4 1.8TQM6
wonderin' what lenth (miles) you guys wait b4 doing oil changes on u'r 202's...pre FSS.
dealer writes 5000 miles on my window sticker...
how long do you wait?
02 W163, 84 W123, 03 E39, 98 E39
Re: those with pre-97 w202's
I would change every 7,500 miles or every 12 months (with synthetic oil), whichever comes first unless you do lots of city, stop & go driving. Under hard useage circumstances, every 5,000 miles would be reasonable.
FYI. I have (had) three W123 with over 200,000 miles each that I religiously changed the oil every 5,000 miles and never had any engine problems. That is not to say the engines in the W202 are anywhrere as well built as the old diesel engines MB use to make. MB reccomendations on oil change intervals for W-123 diesels is every 5,000 miles to remove the sulfuric acid that builds up in the engine oil of diesels because of the sulfur contaminants in diesel fuel.
Oil weight
Originally posted by DougandhisC280
I just use organic 20W50 every 3,000 miles.
There is nothing wrong with Dino oil for 3,000 to 5,000 miles between oil changes, but I choose the synthetic for a bit better gas milage and to streatch the oil changes to the reccomended 7,500 miles.
BTW 20W50 is also a great choice for a higher mileage car in a warmer climate.
1 Post
2008 SLK-280
New leaks with synthetic
That's exactly why I use it. If I switch to synthetic I worry about developing new leaks because of the thinner oil. The way I look at it, I think it is better for me to change my oil and filter twice as much as doing it with synthetic. Because organic oil is so much cheaper, it costs about the same price to do it twice as often.
2016 BMW Z4 sDrive35i M Sport
The dealer set my intervals on my 95 at every 7500 miles. I don't really like it, but that's what they say, so that's what I do. I do believe I run 5W30 Mobil 1.
I change my 10w30 synthetic every 5000 miles, so that way every time my mileage is divisible by 5, I change it. Obviously, you have to start this when your mileage is actually divisible by 5...
Re: Re: those with pre-97 w202's
Originally posted by cil254
Excuse my ignorance, but what does "FSS" stand for ?
87 190E 2.6/1995 M3
when i got my 95 c280 it was leaking oil around timing chain cover.....a couple of oil changes with castrol 10W40 (winter) and then 20W50 (summer), made the leak go away....think whoever had the car before was using 5W30 or something......
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
C280
In a nutshell.....
on my 99 C280 It means I could go up to 10K without changing the oil (according to the manual at least). I believe that there are sensors somewhere in the lubrication system that determine how dirty the oil is. Once it reaches a cetian point, a "countdown" mileage timer is set to visually recommend the next servicing.
