Instrument Cluster 1998 C280
My question is on my instrument cluster everything works great as far as I can tell except the trip mileage,odometer, outside temp,and clock stays illuminated at all times. I left it sit for a couple of days and had to jump it.
Could these lights in the dash be the problem of draining the battery enough not to start. Is there a relay that turns these lights off when the ignition is off with the key out of the car or could it be that the cluster is bad? I have checked all the fuses and connections and the battery is the correct size and is only about 8 months old. Also shouldnt these lights go out when the ignition is off and the smart key removed with all doors closed.
I would appreciate it very much if anyone could or would let me know what their thoughts are on this problem. Thanks in advance for any help that can be provided.
Also could it possibly be the headlight switch?
Not saying that will work, but a start to find the problem.
As far as running the battery flat, those lights don't draw very much.
The dash harness is a straight plug in, so you can't defeat it by eliminating those specific lights.
As mentioned, as soon as the door is open, certain dash lights will come on.
If it was the door switch, I would imagine the interior lights would stay on, and that will certainly kill the battery. Happened to me when it was daylight, and the rear seat light was on, but you couldn't see it.
Strange one for sure, but probably an easy fix.
