Offset on Wheels
Old Sep 9, 2003 | 09:47 PM
Brandon24C's Avatar
2000 C28 Sport
Offset on Wheels
Well with the last post about opening a gas cap, I felt pretty safe posting this one. Hopefully people wont be able to rag on me for asking this question. What is the offset for wheels? When people say, "35mm offset," what does that mean? How do I determine what it is for my car. I have a 2000 280 sport and I am putting 17 monos on it from the C43. Does anyone know? Thanks!
Old Sep 9, 2003 | 09:56 PM
DougandhisC280's Avatar
2008 SLK-280
Just go with something between 35 and 38 mm offset.
It's the millimeters from the hub.
Old Sep 9, 2003 | 10:28 PM
tpliquid's Avatar
too poor now
mono 37 and 32 offset
Old Sep 9, 2003 | 10:42 PM
2008 SLK-280
32 offset
That'll rub like crazy won't it?
Old Sep 9, 2003 | 10:44 PM
tpliquid's Avatar
too poor now
i thinkt hat is the offset on monoblock.
Old Sep 10, 2003 | 12:04 AM
Denlasoul's Avatar
1998 C43
Stock offsets of the C43 are 31mm front and 35mm rear.
The offset is the +/- distance from the center of the wheel width. So in the stock C43 wheels, the Front wheel is 7.5 inches wide and the mounting "face" is 31 mm from the center. On the rears, the wheel is 8.5 inches with a 35mm offset.
Old Sep 10, 2003 | 12:13 AM
2008 SLK-280
I never knew it was the center. All well, you win some, you lose some.
Old Sep 10, 2003 | 01:56 AM
Brandon24C's Avatar
2000 C28 Sport
Thank you for the help. I apologize for the re-post.
Old Sep 10, 2003 | 02:17 AM
henry47's Avatar
asdf
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
source: www.tirerack.com
Old Sep 10, 2003 | 03:32 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
You must have a C43 that thinks it is a 1999 E55.
The AMG Monoblocks that come on the C43 are ET35 front, ET30 rear.
-s-
Old Sep 10, 2003 | 04:35 PM
Brandon24C's Avatar
2000 C28 Sport
Im putting those wheels on a 2000 280. Is that what they are on that car also? Thanks!
Old Sep 10, 2003 | 04:39 PM
moedigga's Avatar
2017 GLE 350 Wifey, 2005 C55 AMG
Brandon, To make you at ease I just put my 17 monos from my c43 on my girlfriends 97 c280 sport and they fit fabulous-MOE
Old Sep 10, 2003 | 06:01 PM
Brandon24C's Avatar
2000 C28 Sport
Thanks MOE, that is good to know. The only reason I am so concerned is because the car is getting dropped next week and having the correct offset is very important to keep it from rubbing. Its going to be about a 2 inch drop in the front.
