Car Jackin'
Old Sep 10, 2003 | 02:32 PM
CBus's Avatar
2000 C280 Sport
Car Jackin'
Do any of you know where or if I can lift the entire front end of my 280with one jack? and also the rear end?
I like to rotate my tires myself, and getting the car up and off the ground so I can take off all 4 tires has been a challange and dangerous.
I have jack stands, but only one floor jack. I know where to jack the car up from on the sides, but was hoping to lift the entire front or rear at once.
Old Sep 10, 2003 | 02:37 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Check out this link
In the Tire and Wheel forum in July. May be of help to you.
https://mbworld.org/forums/showthrea...threadid=44297
Good luck.
Old Sep 11, 2003 | 02:07 PM
soldsep's Avatar
87 300 E
rear = lift on differential
front = axil
correct me if im wrong. I am not an engineer. just another amateur giving out hopefully the right information.
Old Sep 11, 2003 | 04:10 PM
CBus's Avatar
2000 C280 Sport
Ha
Don't worry SOLSEP, I just sue you if it falls on me.
Just Kidding
Old Sep 11, 2003 | 06:35 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
safest way.....is to use 4 jack stands and do it one corner at a time starting with the front....put the jack stands on the crossmembers....something fixed that can carry the weight....that's how my mechanic does mine...
Old Sep 11, 2003 | 07:20 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Car Jackin'
Since you are rotating the tires front to back back to front, why do you need to lift the entire front or entire back at once? You need to lift the entire SIDE at once. So what I do is use a jack with a lot of lift, lift one side under a jack point, put a jack stand under the other jack point (for safety), and move the tires front to back and back to front. Then remove the jack stand and lower the jack.
-s-
Old Sep 11, 2003 | 09:44 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
speaking of tire rotation.....how many of you guys rotate your tires.....?
Old Sep 11, 2003 | 11:17 PM
CBus's Avatar
2000 C280 Sport
I rotate my my front tires to the back, but I cross them also. The front driver side tire gets rotated to the rear passenger side. This way, one tire ends up getting rotated to all positions. eventually.
I try and rotate mine every 5-7K miles. I have a Ford-F150 and I put 97000 miles on the last set of tires. Probably a combination of rotation, correct tire pressure, and most of it was highway miles.
Old Sep 12, 2003 | 02:36 AM
scorchie's Avatar
Which is very bad, if you are using radial tires. And even worse if you have directional tires.
But really, you shouldn't cross the tires. Check your owners manual.
And tires that are made to last that long. Not to mention, it's difficult to get solid axles and "I-beam suspension" out of alignment.
-s-
Old Sep 12, 2003 | 02:37 AM
scorchie's Avatar
How many of us don't have staggered setup and CAN rotate the tires?
-s-
Old Sep 12, 2003 | 03:04 AM
henry47's Avatar
asdf
i can't rotate my tires at all but i CAN dismount them and mount them the other way then swap it to the other side of the car.....that's kinda like rotating
