Charcoal canister purge control valve "open" or "closed" with key-on?
Old Sep 25, 2013 | 01:33 AM
zx636rider03's Avatar
1999 C280 Sport
Charcoal canister shut off valve "open" or "closed" with key-on?
I'm getting a P0450 DTC saying the evap pressure sensor is being triggered. I did a smoke test on on my evap system from the front of the car back and noticed when the ignition is off or on, smoke was coming out of the charcoal canister shut off valve.
Is this suppose to be closed on start-up or key-on? I plugged the hole that went to the valve and the system was holding pressure since i was trying to find leaks.
Trying to determine if it is this unit, or potentially the fuel level sending unit from what my MB book is referring to as possible causes.
Thanks,
Old Feb 14, 2020 | 02:34 AM
Robert Darconte's Avatar
98 C230 W202
Thanks,
Did you ever resolve your issue?
Old Feb 15, 2020 | 08:17 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Hello Robert,
Welcome.
Not sure how this works myself.
Presuming you have the same issue?
here is some reading for you to hopefully assist you in further understanding.
Old Feb 18, 2020 | 07:36 AM
98 C230 W202
Originally Posted by khomer2
Hello Robert,
Welcome.
Thanks for the info! I think my issue is different than the one in the thread. My car keeps throwing a code for evap system leak. The light on the fuel gauge flashes between 3/4 and 1/2 and trips the Check Engine light. I replaced the gas cap and still have the same issue. The potential culprits are not cheap so I am trying to better troubleshoot the issue.
