Transmission won't shift
Old Oct 29, 2013 | 05:58 AM
kuch326's Avatar
2000 C230 Kompressor, 1999 SLK230 Kompressor
Hi, I have a 2000 c230 kompressor with 139k miles and it drives smooth when all of a sudden the BAS/ESP, ABS and the brake wear warning lights turned on and my transmission won't shift up to 2nd gear and up. Also the speedometer doesn't work when the ABS and the brake wear lights are on. They turned on and off intermittently, turned on when the brake pedal is pressed at times.
I tried to accelerate up hoping it will shift up but it turned the check engine light on.
I read on some threads that the brake switch might do the trick but I want to know other fixes. I'll check the brake pads and rotors if they are worn out and clean them well with brake cleaners. I need help please.
Old Oct 29, 2013 | 06:00 AM
kuch326's Avatar
Also, when the ABS and the brake wear are off, the car shifts good.
Old Oct 30, 2013 | 02:34 AM
kuch326's Avatar
I checked the codes and they are P0720 and P0500. Please help guys.
Old Nov 3, 2013 | 09:55 PM
kuch326's Avatar
bimp..
Old May 12, 2014 | 12:25 PM
barry_s_u's Avatar
84 300SD - 93 300E
Did you ever solve this problem? I just had it happen to my SLK230 , 1998. Exact same problem you describe but I can never get it to tturn on without all the warning lights, no speedo and no shift.
