C43 Bosch MAF/MAS Compatible?
'05 A4 1.8TQM6
Re: C43 Bosch MAF/MAS Compatible?
Originally posted by ricerokets4life
anyone know if the c43 bosch mass air flow sensor will fit on a 98 c280 (v6 motor)?
-G-
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
V8 and V6 MAS are different part numbers. So they are intended for different applications. Physically, I believe they are the same size so it will fit. But that doesn't mean it will or will not work properly.
-s-
-s-
did they disable private messaging?
i was just thinking that its MAS must accept a lot of abuse than ours so maybe i would be better off getting one of those if mine happens to go on me
AMG C43, 1999
The C43 MAS is about 8mm larger in diameter and I had one on my 1999 C280, V6. But I had to move it to the other side of the flex hose closer to the manifold.
If installed in the stock location it seemed that the air flow was turbulent and caused the MAS sensor to act funny. But moving to the far side of the flex intake air tubing fixed that.
Jeff
Jeff
