Door Lock Issue
Door Lock Issue
Hello All,
Ever since I owned my '95 C-Class the driver door will only look w/ the key. The vacuum is good on all the other doors, if I try to unlock from the trunk or the passenger side all doors unlock but the drivers side. Only the key will unlock it which sometimes gets stuck during the winter time.
Does this sound like the actuator? I was going to pull the door panel off this weekend to investigate, but was hoping to get some insight as to what I should be looking for, please chime in if you can help me out as it would be very much appreciated! It seems to be a common issue on our cars, so I figured someone out there has tackled this issue.
Cheers!!
Cheers!!
