Noise when I turn
Old Dec 11, 2003 | 02:58 PM
Benz916's Avatar
1998 C230
Noise when I turn
Whenever I make a full turn to the left or right...I hear a rubbing sound. On our 1987 190D we had a shock or something like that had to be replaced then the noise went away. Does my 1998 c230 have this shock...or could the prob be something else?
Old Dec 12, 2003 | 11:32 AM
Spriro's Avatar
1999 C280
I think that's a standard operation, when you turn your steering to the end in either direction there's a screeching sound that alarms you that you made the full turn.
Old Dec 12, 2003 | 07:14 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
hmm check the tie rod ends and the balljoints on the control arms for signs of wear.... ie the boot leaking out all the grease from the joint....
Old Dec 12, 2003 | 11:13 PM
f4i 954's Avatar
2009 e class 2012 ml350
Jack up the wheel & try turnning the wheel side to side to pin point the noise (check lower & upper ball joint)
