P0105 MAP
Old Oct 15, 2014 | 11:02 PM
markjp5's Avatar
2000 C230 Kompressor
Exclamation P0105 MAP
Check your vacuum lines first before buying a sensor . You can get vacuum hose for less than a $1 per ft. After clearing the code it comes back you can check the sensor with a multimeter and a vacuum pump . Its a real simple and easy task . If you have any questions contact me .
