radio wiring diagram
Old Mar 22, 2015 | 07:13 AM
silverdad&wife1's Avatar
1999 c280
need help wiring in aftermarket radio would like to use bose speakers but bypass amp.wires that come out of door speakers are gray and gray and red but do not go to radio.do wires go back to amp first then up to radio? i'm trying to do this myself not very good at it.could use a schematic if anyone could send one please or any advice thanks
Old Mar 23, 2015 | 12:45 AM
ptcruiser's Avatar
C230
When you removed the old stock radio, did you cut the wires to accommodate the after market system. I assume you did?
If you have the old radio, and the original plug to verify the color codes of the wires, then you can trace the speaker wires. There is power (red), ground (brown), and then 8 wires the the speakers. 4 front, and 4 rear, left and right side.
The connections are grouped to right and left. If you make a mistake, it is easy to correct.
Use the original speaker wires to confirm. It may mean pulling off the door panes to confirm.
Getting back to your question, go to the amp first, and then to the speakers.
Hope that helps?
