AMG 18" Monoblocks for the W202
Old May 15, 2015 | 04:08 PM
ssaylor's Avatar
C230
I just picked up a 2000 C230 Sport and would like to update the wheels. Consensus is that the E55s are the way to go.
1294010102 -front 18X8
2104010202 -rear 18X9
What rubber are you all running on these (without any rubbing issues)?
Thanks in advance
Old May 20, 2015 | 11:13 PM
ssaylor's Avatar
C230
nobody?
Old Jun 4, 2015 | 04:22 PM
mbsickness's Avatar
1996 C36
The wheels fit and it is a tight fit to where manufacturing tolerances and tire model will dictate any rubbing issues. I have two w202's and one rubs in front and one rubs in back using the same wheelset. The rear rub is only when the suspension is fully compressed and it rubs on a bump located on the fender liner. Up front the fender might need rolling. The tire sizes I use are as follows:
225/40/18 front
255/35/18 rear
Old Jun 4, 2015 | 04:45 PM
ssaylor's Avatar
C230
Thanks for the info. I think I might go with the 17s from the AMG43 to avoid any offset surprises.
