Charge point on engine W202
Old May 23, 2015 | 03:47 PM
Rebecca3040's Avatar
mercedes C class(2000
Can anyone please highlight where the charge point could be on the engine block , pictures included, we have found something that looks similar to other photographs , but of the 3 leads , lead 2 is going into lead 1 and lead 3 appears to be on its own. It is located in the corner, nearest windscreen, up by the passenger side
Attached Thumbnails Charge point on engine W202-11013271_831699156909244_5751429762665427205_n.jpg   Charge point on engine W202-11128630_831699326909227_8400070243864477427_n.jpg   Charge point on engine W202-11137151_831699306909229_7844133053769546435_n.jpg   Charge point on engine W202-11251626_831699126909247_7089822581856732722_n.jpg   Charge point on engine W202-11265364_831699213575905_6450558820130482430_n.jpg
Charge point on engine W202-11269096_831699413575885_389235717833480988_n.jpg
Old May 23, 2015 | 09:46 PM
swatty's Avatar
220SE Coupe, ML250, E320
The battery is in the trunk/ boot.
Old May 26, 2015 | 12:10 AM
ptcruiser's Avatar
C230
The last photo you posted with the 2 connections in the small box on the drivers side can be jumped and used to operate minor functions, such as door locks, trunk etc. You cannot and shouldn't try to start the car jumping this connection.
As was stated, the battery is located in the trunk on the passenger side under the trunk mat. Positive post is closet to the back seat.
