need help deciding
Old Feb 10, 2004 | 12:38 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
need help deciding
hey all,
ok, my front passanger corner light (stock) has been loose for a few years now and once in a while, i'll have to pop it back in. Plus its cracked...so this gives me an excuse to get clear corners, hehe
anywho, you guys think i should go with the regular clear corners or the crystal clear corners....i havent' seen one with the crystal clears yet...anyone?
Thanks!
Old Feb 10, 2004 | 01:41 PM
ABsC280's Avatar
1995 C280
another option are the stock ambers from germany. let me know if you want more info.
pics from goldeni245
Old Feb 10, 2004 | 01:46 PM
moa4r's Avatar
S4
Re: need help deciding
Originally posted by GDawgC220
hey all,
Thanks!
what are the crystal clear corners?? You should definately get clears for the front, they look very nice on the c-class (get the all clear ones, not the US ones,,, if that is what you mean by crystal clear)
Old Feb 10, 2004 | 04:44 PM
fast mayte's Avatar
98 MB C280
CRYSTALS!!! by the way, anyone got a pic of them on the car?
Old Feb 10, 2004 | 05:10 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Re: need help deciding
yea, they're on ebay and some member from club202 just got 'em for his ride...tho he hasn't posted a pic. Looks sweet tho. Lemme get the link: Crystal Clears
i'm just thinking that it may be too clear for the w202 front and the regular clear corners would look better (cuz my headlights aren't the clear glass ones like newer w202's?) ugh...so undecided between the two. if i had pics of both to compare on w202's that would be great.
Old Feb 10, 2004 | 05:13 PM
moa4r's Avatar
S4
Re: Re: Re: need help deciding
yeah i'd have to see those on a car first...personally, i'd go with the normal white corners,,,good luck man
Old Feb 10, 2004 | 05:18 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Another Sourse
Club202 had this link recently for inexspensive clear coners. No one has reported back how they are yet. In previous posts here, people say the e-bay corners tend to be low quality, don't fit well, fall out, and allow water to come in. Others reccomend Beckkers for obtaining corners, even though more expensive. I do not have any personal experience with any of them.
http://www.perfectautoparts.com/cgi-...ENZ&model=C280
or
http://bekkers.com/
Good luck.
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Re: Re: Re: need help deciding
that's what i'm leaning towards...unless someone's got a pic!?! pleease
Old Feb 10, 2004 | 05:22 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Another Sourse
or
http://bekkers.com/
Good luck.
damn...the ones from bekkers are $127
hmm...the ones i'm checking out from ebay have had other buyers and have left positive feedback on them...maybe i should e-mail those people to see how they're doing...
Old Feb 10, 2004 | 05:23 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
btw...is the bulb for the turn signal amber or clear? because if i change to clear corner, will i have to buy different bulbs? I just thought that since the amber corner is amber that the bulb inside would just be a regular clear one
Old Feb 10, 2004 | 06:55 PM
ricerokets4life's Avatar
yes, the original bulb is amber colored. you can just get replacement OEM clear ones that are DOT/SAE approved at any local auto shop such as Pep Boys and are really cheap. they arent going to blink white like the white of superwhite headlight bulbs though. or you can just get the superwhite corner bulbs.
Old Feb 10, 2004 | 07:14 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
do i have to get replacements if i get the clear corners or the one's in there now are fine?
Old Feb 10, 2004 | 07:46 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
i put a bid on a set. I e-mailed some of the people who bid on the w202 versions as well as w140 versions. They all day that the quality is just like OEM and fit perfectly compared to others they've tried. No leakage or anything.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2459604566
Old Feb 10, 2004 | 08:17 PM
sph17's Avatar
Let us know....
If you get the corners from e-bay how they turn out.
Using the amber bulb in a clear corner gives you the "egg yoke with white around" look.
If this bothers you (as DOT regulations require an amber front corner light, not white) there are special (i.e. expensive) bulbs that avoid this. Pictures I have seen are of a bulb with a silver coating on the outside, like a one way mirror. When the amber bulb underneith is illuminated, the amber shows through. When not lit, the silver coating hides the amber color, and your clears look... well.....clear.
Old Feb 10, 2004 | 09:09 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
yea, i think it's called silvervision or something like that from phillips.
"If you get the corners from e-bay how they turn out."
you mean you want me to let u know how they turn out, right? Will do. Auction ends in about 6 days...so got a little while. It's pretty easy to swap out, right? The bulbs just twist out? Thanks man.
Old Feb 11, 2004 | 05:11 AM
sph17's Avatar
[QUOTE]Originally posted by GDawgC220
[B]
(In the Subject Like) Let us know...... "If you get the corners from e-bay how they turn out."
Old Feb 11, 2004 | 07:09 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
[QUOTE]Originally posted by sph17
[B]
Old Feb 11, 2004 | 09:59 AM
fast mayte's Avatar
98 MB C280
oh stock? it's amber. u can use autozone/oriely bulbs. i put in some blue APC (yes i know they are kinda crap) but they fit in with a little fidling.
Old Feb 11, 2004 | 11:18 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
i may go to homedepot and get what others have been recommending "rustoleum silver high temp" spray paint and just lightly put a coat or two on the bulbs in there now. Everyone that's done it says good results, so may as well give it a shot...worth the $3 instead of the $25 for the pair of bulbs...
i'll try it and let u know how it goes.
Old Feb 11, 2004 | 12:10 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
GDawg, I have aftermarket blinkers too.. I think the're the same brand as the ones you bidding on...
I got them from a friend of mine who had them on his 94 c220, I used them for a few months but now I put them back in their boxes and went back to OEM... I'm thinkng of getting OEM ambers instead (like the ones in the other thread)
To tell you the truth though, aftermarkets fit relatively OK, but only OEM fits perfect...
click the link to see how they look installed on my c280...
GERAC Clear Corners
Old Feb 11, 2004 | 12:30 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
thats not bad at all. once i get them, i'll give 'em a shot...for $28, can't go wrong :p
i'm assuming if others got good ones, this seller is pretty good at getting decent stuff out there instead of the ones that don't fit at all...so cross my fingers.
OEM Ambers? Aren't those the ones we have on our cars now? Or different? I looked at the other ones, but I can't see a difference, or am I looking at it wrong?
Old Feb 11, 2004 | 12:56 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
here we go...someone just put these up for auction with them on a w202...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2459801350
Old Feb 11, 2004 | 03:01 PM
sph17's Avatar
Crystal Clears
Are these similar to the ones that Perfect Auto is selling retail for $17?
EURO CRYSTAL CLEAR CORNERS
one set (left and right included), (202) Chassis
1998 MERCEDES BENZ C280
Our Price: $16.59
Retail Price: $24.92
Old Feb 11, 2004 | 05:20 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Crystal Clears
Our Price: $16.59
I'm pretty sure they are. The crystal clears are too "clear" for my taste...i rather have the regular clear corners.
Old Feb 11, 2004 | 09:19 PM
IMO, crystal clears are too clear and seem to conflict with the headlight housings. even regular clear corners seem to do so but it is still the lesser of two evils kind of deal
