squeeky
Old Mar 1, 2004 | 04:07 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
squeeky
hey all,
When I push my car up and down from the fender up front...it goes "squeeky squeeky"....what can that be? Shocks, struts? I've had the bushings and lower control arm replaced about a year ago...so I don't think that's them. Haven't changed my shocks yet for the life of the car or struts...what do you think?
thanky!
Old Mar 1, 2004 | 07:29 PM
redcoupe's Avatar
11 ML350
Its most likely the sway bar bushings.
You can remove them and put wheel bearing grease on the inside them to keep the fro squeaking.
Try it what do you have to loose.
Brian
Old Mar 1, 2004 | 07:32 PM
DougandhisC280's Avatar
2008 SLK-280
I fixed my squeaks with new shocks.
Old Mar 1, 2004 | 07:53 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Brian
Would you mind writing some simple instructions on how to do this? I'm assuming I have to jack up my car and such, yes?
Thanks!
Old Mar 1, 2004 | 07:54 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I will ask my SA to take a look when I'm in for my next oil change...which is soon. Thanks!
Old Mar 5, 2004 | 06:47 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I asked my SA today about it when I had the ML in. He said 9 out of 10 times when it makes that noise (he described it to me pretty well), it is probably the lower ball joints. My right one is wearing out, but says to replace in pairs. Quoted me around $400 for the front lower ball joints...is this a good price?
Old Mar 6, 2004 | 06:37 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
I fixed my squeak with new shocks too. I love my new Bilstein Sports!
Old Mar 7, 2004 | 12:49 AM
pointman's Avatar
a car that can't do the throttle reset.
GDAWGC220 I TOLD YOU TO DO THAT!!! why didnt you ask me?
Old Mar 7, 2004 | 10:04 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
wha? you told me to check the ball joints? I don't remember that...but if you did, thanks man!
My car is gonna be checked out in 2 weeks when i have some things done (oil change, driveshaft coupler, check ball joints and check brakes)
i'll let u know what they find.
Old Mar 7, 2004 | 02:16 PM
pointman's Avatar
the creaking noise...i would say that i think you should seriously consider the stabilizer bushing. pushdown on the car from top of the fender...can it be replicated?
see... . anyway, that noise is the stabilizer bushings. positive.
Old Mar 7, 2004 | 06:53 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Ah, gotcha. I'll tell them to check into that when I'm in ('bout two weeks). I'll report back then and see what they say.
Old Mar 17, 2004 | 02:32 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
They checked out the car and they couldn't reproduce the problem or find anything worn out excessively that would produce the problem. Lower right ball joint is having a little play, but can wait till next service. Quoted $325 for the front ball joints.
So we'll see next time....but the squeek only comes once in a while, not all the time and of course it wasn't going to reproduce the sound today at the dealer
GDawgC220's Avatar
'05 A4 1.8TQM6
Old Mar 17, 2004 | 02:33 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
GDawgC220's Avatar
'05 A4 1.8TQM6
GDawgC220's Avatar
'05 A4 1.8TQM6
