BAS/ESP and upshift problems
Here is the problem(s). Every once in a while, the BAS/ESP light comes on. This causes the car to act really funny. Sometimes it doesnt want to shift out of 1st (limp home mode?), it shifts hard, and sometimes when its doing this I turn the key and nothing happens. At all.
This problem happens intermittently, but once it starts to happen, it gets more and more frequent. Taking it to a dealer and having hime "clear the codes" seems to take care of it for a week or so but it always returns.
When the problem started, I took it to the dealer, and they found a host of problems, mainly the electronic shifter assembly. Its replaced, and does nothing to correct the problems.
I take it to another dealer and they say "we will fix this, oh yeah well find it, were the best". That lasted about a day. They cant make the car reproduce the problem. So they want me to authoreize 10 hours of diagnostic work for htem to try to run it down.
I got them to pull the history on the car, and it looks like its been having these problems since about 20K miles. The same parts have been replaced several times, leading me to believe that they have no idea how to fix this.
The dealer says that there are codes in the computer, but what its telling them to do doesnt make any sense to them.
Finally they have told me that if I bring it in while its faulting again, they will contact the factory and possibly the factory with authorize them to fix this problem that seems to be very elusive.
So like I said, im at my wits end. If they cant fix this soon im going to just sell the car. Its made me very dissapoined in Mercedes (also in myself for not checking the car at a dealer rather than my local mechanic)
Does anyone have any experience with these problems? Any leads?
Thanks in advance,
Chris
ctorto1@lsu.edu.uk (remove the UK to email me
Upon further talking with them, they say that they will call the factory to authorize the repair since the car has had so many problems. I hope this works out. I really like the car, but when I get in it and it wont crank or holds 1st gear down the block its dissapointing.
I have a feeling its a simple sensor or computer problem that just is not easy to run down. Any ideas of things I could try or check on my own? After reading the forums Im thingkning about looking at
1) MAF sensor - seems to be a recurring theme
2) O2 sensors?
3) checking transmission fluid
4) resetting the car by pulling the battery wires (I have the radio code)
You know that the dealership told me that the problem may have been in the values in the smart transmission system? They told me that for $250 the could reset the system to factory for me (I E it would forget about the previous drivers). From what im reading simply disconnecting the battery will do this.... is this the case?
Thanks for your advice
Chris
Well I did get an aftermarket warranty althought the car was not starmark certified. Its a decent one but it does not cover diagnostics unless they are related to a warrantied part. So basically they want me to front 10 hours of labor for a problem that they admit they may or may not find.
2) O2 sensors?
Chris
Pulling the battery will reset EVERYTHING. All the codes from the computer, clock, radio, adaptive transmission settings. So yeah, u can pull it, let it sit for about 30 minutes then re-attach it. For the tranny to learn your new settings, take about 200 miles or there of.
May want to change the tranny filter...that helps shifting as well. If the thing is clogged, then yeah, u'r gonna get rough shifting probably. I'm not sure if you can change the tranny fluid yourself...as you need special tools I think (may be on the S-Class) but check around on that.
Have you checked the FSS (flexible service system) in the cluster to see how much longer before the next service?
Are you getting these things checked out at a MB dealer, independent MB dealer or just a regular garage?
From the MB records on the car it looks as if it sat upf ro 6 months or so while it was sold (700 mi in 6 months).
I really dont WANT to get rid of this car, hell I just wrecked my GTI and bought this, I love the car, its so clean. I feel like if I just can get past this stupid problem the car will be fine.
Ill keep ya posted.
Chris
