Headlamp issue - Only fog lights working?
Old Feb 6, 2017 | 10:41 AM
mrlament's Avatar
2016 E350
Hi everyone,
I'm having a problem with the headlamps on my car. From what I can tell – only the fog lights are coming on when I switch the headlamps on, although I could swear I see the regular lights flicker on for a millisecond before they switch to the fog lamps when I turn them on.
In addition, I have no brights (which, I'm presuming is because the headlamps that turn on are the fog lights and not the normal low beams).
However, when I turn the car off and set the alarm (activating the temporary courtesy headlamps), only the drivers side headlamp turns on, but it appears to be the actual low beam, not the differently colored fog light.
Any thoughts on what might be going on here and where to look for a fix?
