HELP!!Problem with my shifter
Old Apr 4, 2004 | 02:58 PM
BadAssBenz's Avatar
1996 C280
Ok, so all of a sudden, my shifter has gotten reeeally loose. Its kinda hard to get it into the gear I want cause its just moving around in directions it shouldn't be. Im going to take apart the center console around the shifter to see if I can find a loose bolt or something. Has anybody had this problem? I really dont want to end up somewhere and not be able to put my car in Park.
Old Apr 4, 2004 | 09:15 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
It may be that nut that is holding it. Look straight down into the shaft of the shift knob and u should see a nut there. See if you can tighten that. You can lift up the plastic surround gate by just gently prying it with a flat head screw driver and that will give u a lot more space to work with!
good luck.
Old Apr 5, 2004 | 05:10 PM
DougandhisC280's Avatar
2008 SLK-280
It's probably the rubber bushing for the linkage. The part is 50 cents and the laber is about $30. It won't get any worse, it's just annoying. You can see the bushings from under the car.
Old Apr 5, 2004 | 07:19 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
Shifter bushings. Had the same problem 6 months ago.
Old Apr 6, 2004 | 01:03 PM
BadAssBenz's Avatar
1996 C280
So, is it repaired from the underneath, because I cant see anything accessible from inside the car? Has anybody done this themselves?
Old Apr 6, 2004 | 02:51 PM
BadAssBenz's Avatar
1996 C280
I found two parts, both pretty cheap. One is a pair of clear-looking cylindrical bushings, and the other was a pair of "tapered spool" type bushings. Any ideas??? There both listed under AT Linkage Bushings on one of the linked websites from jagworks.com.
Old Apr 7, 2004 | 01:01 AM
2008 SLK-280
Go with the electric controlled transmission bushings. They are green colored and much easier to get in. Yes you can do it yourself but you will need some long and skinny plyers.
When buying them just say you want bushings for a 98+ w202 c class.
2008 SLK-280
They are installed from under the car.
Old Apr 7, 2004 | 01:49 AM
BadAssBenz's Avatar
1996 C280
I have a 95 c280, not a 98+. Still the same procedure?
Old Apr 7, 2004 | 11:51 AM
2008 SLK-280
yes
