220cdi engine om611 swap 320 cdi engine om613 from w210
mercedes c220 cdi w202
hello there i was wondering if anyone knows if i could fit the 320 cdi om613 engine in my c220 cdi 99 model manual transmission, im planning on buying a e320 cdi w210
Mercedes W202 C200 CDi Elegance
On the same boat...
Did you manage to get anything done, or get some info at least? It's been pretty hard for me to get some good hp from this om611 engine sadly, I'm thinking of doing a swap but have no clue if the om613 or at least the om612 would fit without much of a hassle.
Same boat in 2020
Bump!
Greetings Guys, did anyone managed to install an OM613 with auto trans 722.626 on a W202 chassis?
My daily is a C250TD (currently with a bent head and a blown prechamber)
I own another E320CDI W210 that i already stripped in order to simplify the looms to swap only the engine, trans, shifter, ABS+ESP and all associated hardware in the W202....my concern is that the bellhousing won`t clear the transmission tunnel, can anyone confirm or dismiss this issue?
Thank you!
Thank you!
