taking off shift knob???
Old May 10, 2004 | 01:09 PM
djdoubleg413's Avatar
95 c280
i have a 94 c280 i was wondering how to take off the shift knob?sounds like a dumb question but the friggin thing won't come off. i tried twisting it and it won't budge. does anyone have any suggestions? thanks
Old May 10, 2004 | 02:15 PM
fast mayte's Avatar
98 MB C280
do u have the long shift knob like the 190E's or the shorter leather one like the ML's? the leather ones, u just twist the bottom piece anti-clockwise. i used a pliers for the first time. then just pull up. donno about the 190E style ones.
Old May 10, 2004 | 03:33 PM
ShollyC220's Avatar
C220
oh man
this is how it feels to do this difficult project! I swapped my shift knob out (with a solid wood one) on my 94 C220. Well to say I did it, isn't correct. I attempted to, but it turns out to remove the shift knob from 94 C-classes, you must take apart the whole center console- a job the stealership charged big for- and would take a long time fo a DIY-er. It can be done, but I recommend getting a parts diagram to see how everything comes apart- it'll take awhile. The stealership price...
Old May 10, 2004 | 09:54 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
taking apart the center console (assuming your talking about the wood piece that surrounds the shifter and all the window buttons) isn't very hard. I had to do it when hardwiring my radar and just took my time and figured it out.
So what do you do after you take out the wood piece surrounding the shifter?
Old May 10, 2004 | 10:06 PM
ShollyC220's Avatar
C220
Unless the stealership lied to me (which is possible) you need to take apart more than just that wood piece- you need to be able to access the joint of the shift knob shaft and the tranny
Old May 10, 2004 | 10:24 PM
95 c280
shift knob
i took it off today. all i did was claw away at it. i cut the leather off, then peeled all the rubber off. under that was the metal shaft and a circle on the top. i hack sawed the top off then slid the new knob on like butta. the new one i put on was off a newer benz and had the twist thing at the bottum and that tightened it nicely.
Old May 13, 2004 | 01:51 PM
fast mayte's Avatar
98 MB C280
great job, thats the way to do it!!! can we get the final pictures of the destroyed shiftknob just for the record?
hahhaa
Old May 30, 2004 | 04:41 AM
Faheem Daddy's Avatar
w202 C220
Can someone post some more info on how to remove the shift knob from a 94 C220? I'll be swapping my shift knob soon...and I know with my BMW all you have to do is pull really hard without hitting yourself in the forehead...is that what I'll have to do with my w202?
