iddle issues with my c220
here is my problem, the car iddles fine a 750 rpm, no rough iddle at all. But once i am driving and get to a red light or a stop, and hit the clutch, the rpms drop down to nearly stalling the car, some times stalls de car. it only happens when driving and when clutch is on to get to a stop.
what can it be? does my car has a iac valve? if it does, where is it?
port for scanner is round shaped with a lot of holes and nobody has the scanner to pull codes in my home town, also, my cluster doesn't come equipped with a check engine light
i will really appreciate any help you guys can give me. thanks in advance
