tires rubbing
Old Jun 16, 2004 | 05:05 PM
wkeyau's Avatar
Angry tires rubbing
Hi there,
1995 C280 - I lowered my car with H&R springs and Bilstein shocks. I am having some tire rubbing problem...not often but enough to make me want to fix it. Currently I have #3 spring pads. Do you think I can fix the problem by going up to #5 spring pads? Do the pads have to be the same number for front and rear? Currently the front tires just clear the fender.
Thanks in advance!!!
Old Jun 17, 2004 | 05:11 PM
tpliquid's Avatar
too poor now
wat tires are u running?
wat offset is ur wheel
do u have ur fender rolled?
wat space is between ur tire and fender?
pad # dont do nutin. different cars have different options therefore different pads are installed. so u need to answer these questions first
