differential broke and compatibility
Old Jan 2, 2019 | 01:30 PM
magodeoz73's Avatar
1996 c220 manual
Hi guys, happy new year to all of you.
Last sunday i was on the highway with my family when suddenly we felt something was wrong with the car, i thought it was a tire but no, all 4 were ok, log story short, the car lose traction, i put it on gear and nothing, reverse and nothing ( it is a manual ) , then i recall that it was leaking fluid from the differential, now i have to look for a replacement. Do you guys know if its got to be a c220 specific one ? or could it be a c230, or c280 compatible with my car?
thanks a lot for you answers
Old Jan 2, 2019 | 01:44 PM
ygmn's Avatar
2015 E400 Sedan
just cause it is leaking does not mean differential is toast - could be if it went bone dry and burned up bearings.
I would open up and inspect first as issue could be in tranny?
Old Jan 2, 2019 | 02:22 PM
magodeoz73's Avatar
1996 c220 manual
Thanks for your answer, i detected the leaking 3 months or so a go, so maybe it went dry as you said.
Old Jan 7, 2019 | 09:43 AM
Dirgesan's Avatar
1999 C230K
I don't have any experience with replacing Mercedes diffs, but you can post your VIN and we can look up the part number on EPC. According to this site, a C280 should fit:
https://www.genuinemercedesparts.com...bC1sNC1nYXM%3D
This site is nice, not for buying parts because they are $$$$, but for showing part numbers, diagrams, and possible compatible parts
Old Jan 7, 2019 | 03:02 PM
magodeoz73's Avatar
1996 c220 manual
It turned out to be the differential, sad!
magodeoz73's Avatar
1996 c220 manual
Thanks a lot for the info, i will take a look at it
Old Jan 7, 2019 | 10:00 PM
Dirgesan's Avatar
1999 C230K
Sorry to hear about the diff. It looks like a 95-96 C220 C280 should fit if you can find one in a junkyard. I've heard that if you jack the rear end using the diff it can cause the housing seal to leak, which is a PITA to replace.
