Check Engine Light trouble
My 98 c230 check engine light came on a couple days ago I used a ODB reader from autozone and received a P1519 code which is a Adjustable camshaft timing solenoid. I have no idea what this means but the car is running perfectly fine . I further went on to erase the code but it reappeared 2 days later with the same P1519. If anyone is familiar with this problem or what this problem actually is info would be much appreaciated
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Not sure if it helps:
P1519 Throttle Actuator Control (TAC) Module Internal Circuit
I found a list of codes from the OBD-II at:
Codes
Good luck!
Bob
Codes
Good luck!
Bob
