SRS/Airbag Light
Old Oct 12, 2019 | 03:46 PM
shooter_va's Avatar
2001 E320
SRS/Airbag Light
I am working on a 2000 C280 I recently picked up. Issue is that the SRS light comes on, goes off and comes on again and stays on. The weird thing is that this happens when I turn the key to position 1 (accessory position) and also in position 2/when I start the engine. Scanned for codes at the 38-pin socket under the hood, found a bunch of codes due to recent battery exchange, but no airbag code (I reset all codes found, re-scanned and no codes were present anymore, but still the same issue with the SRS light).
I am baffled why the SRS light on the instrument cluster would come on in the accessory position?!
The indicator light for passenger side airbag on the shifter console comes on briefly in key position 2 and goes off again with nobody sitting in that seat.
All fuses are good.
Does anyone have an idea about this issue?
Thanks.
Old Oct 17, 2019 | 04:59 PM
Dirgesan's Avatar
1999 C230K
Which 38-pin scanner are you using? If there's no codes you might just need to reset the SRS. Unfortunately, the only scanner that I know of that can reset the SRS on a 2000 besides the dealer's MB Star Diagnostics is the Carsoft 7.4 Multiplexer.
MB Medic has a nice article on it here:
http://www.mercedesmedic.com/srs_airbags/
Old Nov 18, 2019 | 01:45 PM
shooter_va's Avatar
2001 E320
I had the codes scanned by a friend who has a professional scanner and he pulled SRS related code 034, but for the description it only mentioned "Please refer to vehicle service manual".
