asr bas problems
my problem started about 5 years when I had to change the key, key contact and imo. do not know from what car or model were all of these been taken but that guy by changing these my car started.
but since then when i need power the car goes into limp mode and ASR BAS lights up.
since than I have been with my car to different mechanics and all of them tryed to fix it by changing different components in the engine computer.
but all of these with no luck. my car does just the same ...when you hit hardly the gas pedal it goes into limp mode. if I do not force the car , I can go anywhere with no problem.
my car is a C230K from 98.
after testing with STAR I have the folowings:C1022, C1025, C1004, C1060 , errrors which I can not delete.
all of them by CAN lines.
i have changed the ABS computer(by code is from a CLK), brake pedal sensor, meassured the harnes, tried to put in the same line all of the sams, none of these with no luck.
can anybody help me?
thank you very much.
Are you sure the bps is not defective? I would test it - https://mbworld.org/forums/e-class-w...lem-fixed.html
